The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find a blade to suit every requirement. Bore size 30mm. Thin kerf blades offer the advantage of less power being required to produce a cut, especially useful for mitre saws and brush motor powered bench saws. You should check that your riving knife can accommodate a thinner than standard blade. N.B. Bore reducing bushes are not suitable for use with these blades.
