Axcaliber Flush Trim Cutter with Down Shear - Bottom Bearing
- For flush trimming or following a template
- Cutting edges, angles give a downward shearing action
- Produces a very clean cut with minimum breakout
- Fitted with bottom bearing
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/2" shank
Axcaliber Router Cutter Bearing - D=19 - X=6.35mmSpecial Price £1.34 £1.12 was £4.48 £3.73 Save £3.14 £2.62
An excellent choice for flush trimming or following a template, these cutters have the cutting edges placed at an angle to give a downward shearing action. This results in a very clean cut with minimum breakout. Bottom bearing cutter with 1/2"(12.7mm) shank, 19mm diameter and 50mm depth of cut.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter | 19 mm |
EAN Barcode | 5052511047130 |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 50 mm |
