Axcaliber Round Over Cutters - 1/4" Shank
From £7.14 £5.95 was £21.98 £18.32 Save £14.84 £12.37
2 Reviews
  • Use with side fence in a router table
  • Change the depth of cut to produce top or bottom quirk
  • Cut from both faces of work for a bull nose edge
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
  • 1/4" shank
Assurance with Axcaliber
- see how they're made
A range of roundover profile cutters offering three of the most popular radii. As these cutters are not bearing guided, they would need to be used with a side fence for hand held use or used inverted in a router table utilising the fence.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
5.00 2
