Axcaliber Stile & Rail Cutter (Ogee)
666220
666220
- One cutter produces both the moulding and scribing cuts
- Excellent for custom made kitchen cabinet doors
- Attractive ogee style profile
- PTFE coating helps minimise resin build-up
- This cutter is for use in router tables only
- 1/2" shank
Show more
Show less
This Axcaliber stile and rail cutter offers an attractive ogee style profile with the advantage of having just one cutter for both the moulding and scribing cuts. Excellent for making your own kitchen cabinet doors. Please note that for reasons of accuracy and safety these cutters should only be used in a router table. The timber should be positioned to face down on the table for the profiling cut and face up for the scribe cut.
C = Width of Groove | 6.35 mm (1/4") |
D = Overall Diameter | 41 mm (1.5/8") |
EAN Barcode | 5052511030613 |
H = Horizontal Depth of Cut | 9.5 mm (3/8") |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 23 mm |
