Axcaliber Twin Flute Small Diameter Straight Cutters - 1/2"(12.7mm)
AX807619
AX807619
- 1/2" shank helps eliminate vibration
- Eliminates chatter under load
- PTFE coating helps minimise resin build-up
- 1/2"(12.7mm) shank
Show more
Show less
A high quality range of small diameter twin flute 1/2"(12.7mm) shank cutters. Produced using advanced technology on up-to-the-minute multi axis CNC machinery. Shanks made from SAE4140 steel hardened to Rockwell 45 HRC, renowned for its hardness and strength, and the tips are made from diamond ground micrograin tungsten carbide.
Shank Diameter | 1/2" (12.7 mm) |
#AxminsterTools
