Axminster Workshop Barrel Plug Cutters
- For cutting plugs and short dowels up to 50mm in length
- Timber can be matched to cover screw heads etc
- Clean cutting and easy plug removal
- For use in drill presses only
These barrel cutters will cut plugs and short dowels up to 50mm in length, when matched with a corresponding drill they can be used to cover screw holes or make a small repair in damaged timber, they also make a good decorative plug. Designed for use in a drill press they give a very clean cut.
