Axminster Workshop Benchcraft Tenon Saws
AX19916
AX19916
- Well shaped solid beechwood handle
- Heavy gauge brass back
- Tempered spring steel blade
Show more
Show less
Fulfilling the need for a traditional, quality brass backed tenon saw, for the discerning occasional user, the classroom or training college. The Benchcraft saw has a solid well shaped beechwood handle, heavy gauge brass back and a tempered spring steel blade. The blade is 60mm(2.3/8") deep. The 250mm(10") long blade has crosscut teeth cut at 15tpi, the 300mm(12") long blade has crosscut teeth cut at 13tpi.
Kerf | 0.83 mm |
Model | AB10 |
