Axminster Workshop Clear Reinforced PVC Hose - 63mm x 2.5m
- Heavy-duty hose: polyester-polyurethane wall
- PVC coated spring steel wire clockwise spiral
- Will not crush or distort when bent
- Flexible with a smooth internal bore (63mm)
- Abrasion resistant and almost penetration proof
Axminster Workshop Quick Release 63mm Hose Fixing Clip (Pkt 2)From £6.98 £5.82
Use this 63mm clear hose to make the connection between fixed rigid ducting or a mobile dust extractor and a machine. It is heavy-duty polyurethane (PU) hose with a polyester-polyurethane wall and an embedded PVC coated spring steel wire helix (clockwise spiral). The hose keeps its shape even around a sharp bend. The internal bore is moderately smooth minimising friction and the likelihood of a blockage. The hose is abrasion resistant and almost penetration proof. Temperature range of -40°C to +100°C.
EAN Barcode | 5052511073092 |
Hose Diameter | 63 mm |
