Axminster Workshop 63mm Extraction Hose with Clips - 3m
- 3m length of 63mm clear, spiral wound lightweight dust extraction hose
- Nice and flexible, this is perfect for the home woodworker
- 63mm is a common size of dust outlet found on many popular machines
- Supplied with two clips
- Can be easily cut to length if required
Axminster Workshop Tee Joiner for 63mm Dust Extraction KitFrom £4.68 £3.90
Axminster Workshop Blast Gate for 63mm Dust Extraction SystemFrom £3.58 £2.98
This is a 3m length of 63mm clear, spiral wound lightweight dust extraction hose. Nice and flexible, this is perfect for the home woodworker. 63mm is a common size of dust outlet found on many popular machines. Supplied with two clips. Easily cut to length if required.
EAN Barcode | 5052511116812 |
Hose Diameter | 63 mm |
