Axminster Woodturning Mounting Plate For Tool Posts - 75mm
- 75mm diameter mounting plate
- Threads directly onto Axminster tool post
- Mount work for decoration or carving
- Circular grooves aid blank centring
For the smoothest turning
The Axminster Woodturning Tool Rest System is made entirely of stainless steel which means it's corrosion and rust free. The chisel glides seamlessly across the rounded bar without any nicked interruptions.
There are two simple steps...
The stainless steel round bars form the perfect tool rests and screw into the posts. Choose a selection of straight and curved rests - plus a mounting plate - to suit all your turning projects. Each of the accessories will fit a single tool post so it's easy to swap between them as you turn!
1. Select a post
Choose a diameter to suit your lathe
- 16mm x 110mm long
- 19mm x 115mm long
- 25mm x 140mm long
- 25.4mm x 140mm long
- 30mm x 180mm long
2. Choose your rests or mounting plate
- 100mm - for working in confined spaces, ideal for box making
- 150mm - a middleman for general size turning!
- 200mm - for gaining more access and supporting the chisel when turning deep inside vases and other hollow forms
- 250mm - long length allows for deep support for the chisel inside bowls or longer pieces between centres
- S Shaped - gain greater control and get closer to the bowl when turning
- Mounting plate - useful for when you're carving, drilling, finishing etc
This 75mm diameter mounting plate screws directly onto the top of an Axminster tool post, in place of the tool rest. It allows you to mount work for additional embellishments, carving, drilling, finishing etc. Like the rest of the Axminster Woodturning range, quality is the result of precision CNC machining. It features concentric circular grooves to help centre the blank on the plate. A slight countersinking of the top of the holes on the front face helps to ensure proper seating of your workpiece.
