Axminster Woodturning Ring Point Tip For Deluxe Live Revolving Centre
- Ring Point applies pressure over a relatively wide area
- CNC machined from stainless steel
- 8mm diameter matches the ring drive centre
Axminster Woodturning Dale Nish Tip For Deluxe Live Revolving CentreFrom £11.28 £9.40
Axminster Woodturning Conical Tip For Deluxe Live Revolving CentreFrom £7.98 £6.65
The Ring Point for the Axminster Deluxe Live Revolving Centre applies pressure to your work over a relatively wide area making it particularly useful for delicate timber or soft wood liable to split. You can adjust the amount of compression to suit the timber. The 8mm diameter matches the Ring Drive Friction centre allowing you to swap your work end over end without losing concentricity. 24mm long.
EAN Barcode | 5052511067039 |
