Axminster Woodturning Light Pull Drive
- Light pulls - a great way of using up odd bits of timber!
- Friction drive with 3mm, 6mm, 10mm and 16mm steps
- Extended to keep work well away from headstock
Hermes RB 406 J Flex Ultimate Abrasive 100mm x 10m - 120gFrom £57.78 £48.15
Micro-Mesh Soft Touch Abrasive Pads 50 x 50mm - Mixed (Pkt 9)From £15.58 £12.98
The Light Pull drive is a friction drive with steps 3mm, 6mm, 10mm and 16mm. Designed to help turning light pulls and similar small items with a through hole. Simply slip the blank onto the drive, bring up the tailstock with a revolving centre for support and away you go. The drive is designed to allow plenty of room to work around the light pull, including sanding and finishing. Using the Light Pull drive is a great way to use up all those small offcuts, which are too good to throw away.
