Axminster Professional Power Blade Tape - 5m/16ft
102564
102564
- Double sided 2-colour blade with patented hi-viz printing
- Easy marking of straight lines when the blade is cupped against the workpiece
- Ultra durable tape coating
- Ergonomically designed case with moulded rubber grip
- Patented double magnetic end hook
- Class 2 accuracy, metric and Imperial graduations.
- True zero tip
- Belt clip
Show more
Show less
The Axminster Professional Power Blade has a dual printed blade and is one of the hardest wearing tapes available. The ultra durable coating is ten times more durable than standard blade coatings. The coating protects both the printed graduations and markings, thus extending the life of the tape. The patented double neodymium magnetic end hook not only aids measuring, but also is a handy tool for picking up any screws or small tools which are dropped. 5m tape length, tape width 27mm. Metric and Imperial graduations.
EC Accuracy | Class II |
Graduations | Metric and Imperial |
Tape Length | 5 m / 16 ft |
Tape Width | 27 mm |
#AxminsterTools
