Axminster Workshop 32mm Flexible Hose Non-Flammable
107753
From £101.48 £84.57
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • Flexible galvanised steel, heat and abrasion resistant
  • For extraction connection when grinding or sanding metal
  • Supplied in 2m lengths
This hose is made from galvanised steel spirally wound to give it the flexibility needed when connecting a machine to a dust extractor. In industry this hose is used for ducting smoke and fumes and handling ash etc. It is completely non-flammable, heat and abrasion resistant. In the workshop we recommend its use when grinding or sanding metal and any other application likely to produce sparks, hot or abrasive particles. An appropriate extractor is a must. It has an internal diameter of 32mm (1.1/4") (O/D 37mm) and can be bent to a radius of 96mm. Supplied in 2m lengths.
Note: To allow this to fit easily onto the dust outlet of the Ultimate edge, one end has been slightly flared by 1-2mm,
