If you are tight on space, this wall mounted extractor is just what you need. Ideal for smaller workshops, the Axminster Professional AP50E 1HP Extractor saves much needed floor space while safeguarding your health at the same time.
Handles different dusts
This chip extractor is able to handle chippings, as well as coarse and medium fine dusts.
Putting your safety first
The 1hp motor generates 1,000m³/hr of airflow and is fitted with a 1 micron rated cartridge filter. A waste collection bag is attached.
Space Saving
Perfectly suitable for woodturning, especially where floor space is at a premium, this extractor is also ideal for connecting to stand alone machines.
Before installation, please ensure your wall is capable of supporting the extractor's weight.
Maintained Airflow
The extractor is fitted with a crank handle and paddle system for keeping the filter clean and safe.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
This wall mounted extractor is perfectly suited to small workshops, woodturners or for connection to a stand-alone machine. It is especially suited to situations where floor space is at a premium. Well constructed and efficient, its 1hp motor generates 920m³/hr of airflow and is fitted with a 1 micron rated cartridge filter. This is able to handle chippings and both coarse and medium fine dusts. The collection bag is clipped to the bottom of the filter; if you wish to fit a larger bag, please support it underneath on the floor or the weight of a full bag of waste may be enough to pull it off the filter. The filter has a crank handle operating a paddle to keep the interior clean, use this periodically to maintain filter efficiency. Please make sure your wall is capable of supporting the extractor's weight.
Machine Classification
