Axminster Professional Heavy Duty Variable Height Extraction Hood
410073
410073
From £94.68 £78.90
  5. Half Star
14 Reviews
  • For extracting waste from a dust source where direct connection to the machine is not possible or convenient
  • Adjustable in height from 710mm to 1,220mm
  • Tilting facility enables the collection slot to be positioned at the best possible angle
  • 100mm diameter hose connection
  • Cast alloy hood with a 300 x 50mm collection slot
For extracting waste from a lathe or other dust source where direct connection to the machine is not possible or convenient. Adjustable in height from 710mm to 1220mm with tilting facility to enable the collection slot to be positioned at the best possible angle. The hood is made from cast alloy and the collection slot measures 300 x 50mm. It is easily connected to 100mm flexible hose leading to an extractor of around 1,000m3/hr. Extraction from a woodturning lathe can present problems, using the 200797 100mm Stayput extraction hose fitted into this nozzle and set up behind the lathe makes for very efficient extraction.
4.40 14
