Axminster Professional Dado Blade Table Insert
109598
109598
- Table insert for AP254SB when using dado blade
- Replaces standard table insert
- Aluminium with 25mm wide slot
Show more
Show less
This table insert fits the AP254SB Professional Saw Bench. It is required when using a dado blade, replacing the standard insert. The slot is 25mm wide to accommodate the dado blade. It is used with the saw blade set at vertical only. Made from aluminium.
#AxminsterTools
