From £749.98 £624.98
  • The ultimate package to achieve the ultimate edge
  • Robust well built sharpening, linishing, polishing system
  • Be prepared for a huge variety of tasks with this kit
Customers Also Bought
The Axminster Professional AP50UE Ultimate Edge offers a controlled, repeatable and effective method for sharpening, linishing or polishing on all your edge tools. No one takes up sharpening as a hobby, but it is a necessity in order to get the best out of an edge tool. With this Ultimate Edge Package, you will be ready for a huge variety of sharpening and polishing tasks, so you won't be caught unprepared.
The Ultimate Edge is a variable speed sharpening system which allows you to run the machine in both forward and reverse. By running the belt in reverse (away from the tool), we believe it gives you greater control, generating less heat and, ultimately, giving you a better edge.
The AP50UE Ultimate Edge is fantastic at bringing old tools back to life. If you have some of your granddad’s old tools in a box at the back of the shed, the Ultimate Edge can combine fast rust removal with effortless polishing and incredible sharpening and honing capabilities. It is worth remembering, many of these old tools were made from the best steels available.
The possibilities of the Ultimate Edge are endless. The machine has a 560W DC brush motor, which has high torque and is quiet running. The variable speed allows you to match the speed to the type of abrasive and the tool. Dust extraction ports top and bottom allow effective extraction whether running forward or reverse. The belts can be easily changed with a quick release door lock, an auto-tension lock, and easy-to-adjust belt tracking. The belt platen is fully adjustable to the belt; an optional graphite slip plate is provided. There is a simple table provided as standard. The base is 5mm plate steel and is provided with adjustable feet for bench mounting.
Now available as a package; we've added ten top accessories together with the Ultimate Edge Sharpening System so you will have everything you need for sharpening, right at your fingertips. The package includes:
Axminster Professional Ultimate Edge (107658)
Axminster Professional Ultimate Edge Universal Sharpening Table (105426)
Axminster Professional Honing Guide Assembly for Ultimate Edge (105281)
Axminster Professional Ultimate Edge Twist & Fix Arbor (105419)
Axminster Professional RB377 YX Abrasive Belt 50 x 785mm 240G (105235)
Axminster Professional RB377 YX Abrasive Belt 50 x 785mm 400G (105237)
Axminster Professional Twist & Fix 100mm Stitched Polishing Mop (105422)
Axminster Professional Twist & Fix 100mm Felt Wheel - Medium (105579)
Axminster Professional Twist & Fix 100mm Nylon Abrasive Wheel - Medium (105582)
Axminster Professional Honing & Polishing Belt For Ultimate Edge (104737)
Axminster Workshop Pink Polishing Compound (105926)
  • Support bar with dual axis adjustment and angle gauge included
  • Variable speed 560W brush motor produces plenty of power
  • Easy belt changing and tracking adjustment
  • Forward or reverse, effective extraction in either direction
  • Wide range of accessories allows customisation
  • 50mm wide abrasive belt, 200-600m/min belt speed
  • Comprehensive range of abrasive belts available
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
