Axminster Professional Deep Throat G Clamp
- Large throat capacity for longer reach
- Light in weight if large numbers are needed
- Drop forged for strength, fine rolled thread, rapid adjustment
- 50 mm x 95 mm - 190Kg max clamping pressure
- 75 mm x 120 mm - 350Kg max clamping pressure
Titebond III Waterproof Wood Glue - 3.8litres (1 US Gall)From £69.98 £58.32
See the entire range
Every workshop ought to have a few deep throat G clamps, as they’re invaluable for reaching into those slightly more inaccessible areas that are out of reach to standard clamps.
Lifetime guarantee.
