Axminster Professional Forged Quick Lever Clamp
- Fast action combined with powerful clamping force
- Ratchet and lever mechanism quickly applies pressure
- Nickel and chrome plated to resist corrosion
Titebond III Waterproof Wood Glue - 3.8litres (1 US Gall)From £65.68 £54.73
See the entire range![Lifetime Guarantee](https://axminstertools.imgix.net/cms/product-content/axminster-professional-clamp-lifetime-guarantee/axminster-professional-clamps-lifetime-guarantee.png?auto=format%2Ccompress)
These clamps combine speed with power. The ratchet mechanism gives an increased mechanical advantage and makes it easy to apply full pressure. Pressing the release button instantly relieves the pressure. These are extremely versatile clamps and are unaffected by vibration. Useful for many jobs, such as with jigs or temporarily holding parts whilst drilling.
A removable plastic stop on the end of the clamp allows the arm to be removed, turned around, and repositioned. This means the clamp can also be used as a spreader.
120 mm x 60 mm – 160kg max clamping pressure
160 mm x 80 mm – 300kg max clamping pressure
200 mm x 100 mm – 350kg max clamping pressure
Lifetime guarantee.
![Axminster Professional Clamps come with a Lifetime Guarantee](https://cdn.axminstertools.com/media/cms/brands/warranty/warranty-ax-trade-clamps.jpg)
