Axminster Woodturning Cylinder Jaws - 25mm
310424
From £97.28 £81.07
15 Reviews
In Stock - Ready to dispatch
  • Potential gripping range: Cylinder 20mm to 38mm
  • Internal and external dovetails on end of jaws
  • Potential gripping range: Internal dovetail 22mm to 40mm
  • Potential gripping range: External dovetail 55mm to 70mm
  • Recommended for SK100 and SK114 chucks
  • Drawing dimensions taken when jaws form a true circle
  • Cylindrical bore supports long, thin blanks
  • Made exclusively by Axminster in Axminster
  • Made from stainless steel to protect against corrosion
When turning long and thin projects it's a great advantage to be able to grip a blank along a substantial amount of its length to impart a good measure of stability to the workpiece. To overcome this problem we have designed these Cylinder Jaws with a 25mm diameter by 49mm long bore to accommodate a range of workpiece diameters. In addition, because we are always loath to provide you with jaws which perform only one function, we have added internal and external dovetails on the ends. Suitable for SK100 and SK114 chucks only. As with all our dovetail jaws they simply bolt onto the Accessory Mounting Jaws. Made from stainless steel to protect against corrosion.
British Made British Made
5.00 15
