Axminster Workshop AW300DS 300mm Disc Sander - 230V
107672
From £219.98 £183.32
  5. Half Star
45 Reviews
  • Quiet 750W induction motor with disc brake and NVR switch
  • Tilting cast iron sanding table with mitre fence
  • Efficient dust extraction, supplied with connector for vaccuum extractor
A strong, versatile disc sander that won’t break the bank!
Perfect for any hobbyist's workshop, the build quality and performance of this sander really does speak for itself when you see it in use.
So sure are we of the quality of this disc sander, we cover all parts and labour free of charge for three years! Find out more
Ideal for a range of applications
This disc sander is great for outside curves and sanding 'to the line'. It's also useful for smoothing materials such as wood and plastic, and will also remove small amounts of waste material.
Strong and sturdy design
More than capable of withstanding many types of sanding tasks, the generous cast-iron table tilts to 45 degrees with a slot for adjustable mitre fence.
Plenty of power
A quiet 750W induction motor proves ample power to handle your projects, while a disc brake and NVR switch safeguard you for complete peace of mind at all times.
The AW300DS has an 300mm diameter aluminium disc driven by a quiet 750W induction motor. It has a no-volt-release switch and a brake to slow the disc down in a reasonable time.
The cast iron sanding table has a ground top surface with a slot for the mitre fence. The unique mitre fence has two faces at 90° and can produce LH and RH 45° bevels without resetting. The table tilts up to 45° and firmly locks at both sides.
Efficient dust extraction is via a 63mm outlet. A 450mm length of flexible hose is provided with the machine for connection to a vacuum or similar extractor.
Overall, the AW300DS is solid, weighty and stable and does a good job when it comes to sanding to a line and similar tasks.
Self adhesive abrasive discs are available in a wide range of grits.
Tip: Self adhesive discs can easily be removed complete with their glue by gently warming with a hot air gun (or a simple hair drier) before removing.
Please note: these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Warranty Axminster Workshop 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
4.40 45
