Bahco Handled Hand Files - 200mm
- File flat surfaces and sharp corners, use for deburring
- Suitable for work in high-alloy tool steels
- Files are double cut with one edge uncut, one edge single cut
The Bahco 1-100 Hand files with handles are for filing flat surfaces, sharp corners and shoulders as well as for deburring. A double cut file may also be used for work in high-alloy tool steels. Also useful for the sharpening of heavy implements. High removal rate. Edges and surfaces parallel. Surfaces double cut, one edge uncut, one edge single cut.
File Length | 200 mm |
File Type | Hand |
