Blum Modul 100 deg. Hinge & Cruciform Mount Plate With Screws
717587
717587
- All metal nickel plated hinge 100° opening
- Spring-closing mechanism, slide-on top arm
- Nickel plated steel cruciform for Modul hinges, supplied with pre-mounted screws
- 3-dimensional adjustment (with mounting plate)
- Height adjustment ± 3mm
Show more
Show less
An all metal nickel plated hinge, with 100° opening. It has a spring-closing mechanism and a slide-on top arm plus 3-dimensional adjustment (with relevant mounting plate). Supplied with a nickel plated steel cruciform for Modul hinge with pre-mounted screws. Height adjustment is ±3mm.
EAN Barcode | 5052511077519 |
Model | 915M2550 |
