This TCT saw blade fits the Bosch GKS12V and Makita HS300DW cordless circular saws. It is 85mm diameter with a 15mm bore. The kerf is 1.1mm and the steel blade thickness 0.7 mm with 20 tungsten carbide teeth. The blade is universal, producing fast, precise, quality cuts in all standard applications of woodworking including flexible, rigid, pressing, coating and plywood, chipboard and blockboard. The inductively brazed carbide alternating teeth (WZ), with an aggressive cutting angle, ensure a simultaneous fast and precise cut.
