Bosch C470 Delta Abrasive 100 x 150mm (Pkt 10)
AX1006126
AX1006126
- Aluminium oxide with hook and loop backing
- For Bosch GSS 160 and other delta palm sanders
- 7 hole perforation for dust extraction
- Suitable for use on wood, paint, varnish
Show more
Show less
High quality Bosch 100 x 150mm C470 abrasive sheets with hook and loop backing. These delta shaped sheets fit the Bosch GSS 160 and other brands of delta type palm sander. C470 abrasive is suitable for use on wood, paint, varnish and roughcast, and has a calcium stearate coating to minimise clogging. There are 7 holes per sheet for dust extraction. Supplied in packs of 10.
Abrasive Backing | Paper and Hook and loop |
Abrasive Sheet Size | 100 mm x 150 mm |
Abrasive Type | C470 |
