Bosch AIZ 32 EPC C-Tec HCS Plunge Cut Blades (Starlock)
From £10.38 £8.65
3 Reviews
  • High carbon 32mm steel blades
  • For cutting wood and plastic and other similar materials
  • Cut up to an edge or in the centre
  • Clean cutting
  • Allow for a deep plunge cutting
  • Starlock fitting for maximum power transfer
These high carbon 32mm steel blades will cut wood and plastic and other similar materials, they cut right up to an edge or in the centre of material giving a clean cut as well as allowing for a deep plunge cut if required. Curved-Tec used on the end of the blade features a rounded cutting edge for smoother and more precise plunge cuts as well as reduced tooth breakout on the sides.
Suitable for Bosch, Makita and Fein (10mm) Multi-Tools and others using the Oscillating Interface System (OISâ„¢) or Starlock fitting for a secure fit with maximum power transfer.
5.00 3
