Bosch Impact Control Screwdriver Bits PZ2 150mm (3)
107244
From £8.58 £7.15
1 Review
Low Stock - Ready to dispatch
  • 150mm long, Double ended, impact 1/4" hex bits
  • Long length allows easier access in hard to reach areas
  • Specially heat treated torson zone, 10 x life of standard impact bits
This set of three extra long impact bits, allows you access to screw heads in deep recesses or other hard to reach places. These are double ended with Pz2 tips and 150mm long. Bosch Impact Control double ended bits are as tough as it gets. The bits are fully impact rated and suitable for use in high torque impact drivers. They will last up to ten-times the longer than standard impact bits.
The bits are S2 Modified Steel with an extended torsion zone, which absorbs peaks in torque, greatly reducing breakage.
5.00 1
