Bosch Impact Control Screwdriver Bits PZ2 25mm (25)
- 25 super tough Pz2 impact rated bits
- 10 times life of standard impact bits
- Suitable for use in high torque impact drivers
- Specially heat treated torson zone
- 25mm, 1/4" hex bits for all screw driving needs
- Supplied in handy tic tac storage box
Bosch SELFCUT 6 Piece Speed Flat Bits Set (Hex Shank)Special Price £25.00 £20.83 was £32.58 £27.15 Save £7.58 £6.32
These Bosch Impact Control bits are as tough as it gets. The bits are fully impact rated and suitable for use in high torque impact drivers. They will last up to ten-times the longer than standard impact bits. The bits are S2 Modified Steel with an extended torsion zone, which absorbs peaks in torque, greatly reducing breakage.
There are twenty-five Pz2 bits 25mm long with 1/4" hex shanks supplied in a handy tic tac box for storage and quick identification. The box keeps the bits secure when not in use.
Bit Length | 25 mm |
Bit Size | Pz2 |
Bit Type | Pozi |
EAN Barcode | 3165140980234 |
Model | Impact control Pz2 |
