Bosch Impact Control Screwdriver Bits Torx Mixed 25mm
107233
From £6.88 £5.73
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • 8 Super tough impact rated bits
  • 10 times life of standard impact bits
  • Suitable for use in high torque impact drivers
  • Specially heat treated torson zone
  • 25mm long, Torx 1/4" hex bits for all screw driving needs
  • 1 x T15, 2 x T20, 2 x T25, 2 x T30 and 1 x T40
  • Supplied in Pick and Click system holder
These Bosch Impact Control bits are as tough as it gets. The bits are fully impact rated and suitable for use in high torque impact drivers. They will last up to ten-times the longer than standard impact bits. The bits are S2 Modified Steel with an extended torsion zone, which absorbs peaks in torque, greatly reducing breakage.
This set of eight bits comes in a Bosch Pick and Click system holder, which keeps the bits secure when not in use. The holder can be used alone or easily clicked into the Bosch Pick and Click Cases M or L for replacement or replenishment.
This set comprises eight 25mm long Torx bits with 1/4" hex shanks:
1 x T15, 2 x T20, 2 x T25, 2 x T30 and 1 x T40.
