Bosch T101AOF Jigsaw Blades Special Laminate (Pkt 3)
- Especially designed for tight curves in wood laminates
- Clean precise cutting on both sides of the laminate
- Pack of 3
5 - 15mm, tight curves in wood laminates, clean precise cutting on both sides of the laminate.
Blade Type | Bi-metal, Ground and Taper Ground |
EAN Barcode | 3165140393423 |
Jigsaw Blade Length | 82 mm |
Jigsaw Blade Type | Tight Curves |
Max Cutting Depth | 15 mm |
Model | T101AOF |
Pack Quantity | 3 |
Tooth Pitch \ tpi | 1.40 mm \ 18 tpi |
