Bosch T144D Jigsaw Blades Fast Wood Cutting (Pkt 5)
900312
900312
- 5-45mm soft wood, chipboard, plywood and fibre boards
- Available in packs of 5
Bosch T101BR Jigsaw Blades Reverse Cutting For Wood (Pkt 5)From £7.58 £6.32
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood (Pkt 5)From £6.68 £5.57
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)From £13.68 £11.40
Show more
Show less
Soft wood 5-45mm, chipboard, plywood and fibre boards.
Blade Type | HCS, Ground and Set |
EAN Barcode | 3165140006842 |
Jigsaw Blade Length | 74 mm |
Jigsaw Blade Type | Fast Cutting |
Max Cutting Depth | 45 mm |
Model | T144D |
Tooth Pitch \ tpi | 4.23 mm \ 6 tpi |
