Bosch T127D Jigsaw Blades Metal & Plastic Cutting (Pkt 5)
900306
900306
- 3-6mm mild steel
- 3-15mm non-Ferrous metals and aluminium alloys
- 20mm lead and tin
- 30mm plastics, 20mm reinforced plastics
- Pack of 5
Bosch T101BR Jigsaw Blades Reverse Cutting For Wood (Pkt 5)From £7.58 £6.32
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood (Pkt 5)From £6.68 £5.57
Show more
Show less
Metal: Mild steel 3-6mm thick. Non-Ferrous metals, aluminium alloys 3-15mm thick. Lead and tin up to 20mm thick. Cool with cutting oil.
Plastics: Most plastics up to 30mm thick, reinforced plastics up to 20mm thick.
Blade Type | HSS, Ground |
EAN Barcode | 3165140007313 |
Jigsaw Blade Length | 74 mm |
Jigsaw Blade Type | Straight Cuts |
Max Cutting Depth | 15 mm |
Model | T127D |
Pack Quantity | 5 |
Tooth Pitch \ tpi | 3.00 mm \ 8.5 tpi |
