A very useful tool for cutting metal, stone or tiles ass well as grinding, sanding and wire brushing jobs in the home workshop and garden. Taking a 115mm disc the Bosch UniversalGrind 750-115 will cut paving slabs, trim bricks, cut metal or derust with a simple disc change. The 750W motor delivers plenty of power to handle medium-sized tasks. This tool has a compact design and slim grip for improved comfort and control. Low vibration enable you to work comfortably even for extended periods. It is low in weight and easy to handle. The tool-free protective guard adjustment allows quick repositioning of the guard to control sparks and debris. Bosch’s patented Dust Protection System creates a tight seal around the internal bearings and systems to protect from wear-and-tear caused by dust particles, extending the tool's working life. It is supplied with and auxiliary handle, which can be used on either side of the machine.
Robust 750W motor for medium-sized jobs in home workshop
Versatile cut, grind, sand, brush; masonry, tiles, metal etc
Tool-free protective guard adjustment for added safety
This applies to all DIY power tools, garden tools or measuring tools from Bosch. This tool comes with a FREE two-year warranty, to extend your warranty to three years, simply log into MyBosch. and register your tool within four weeks of purchasing it.
Extended warranty includes: repair service, pick-up and returning your defective device for free. Warranty services are all provided by Bosch directly.
