Bosch 3-Piece Multi-Tool Wood & Metal Cutting Set (Starlock)
- Works well with tools with the universal 12 point mounting
- Starlock interface for maximum power transfer
- Ideal for flush cutting wood and plasterboard
- Use for cutting copper and plastic pipes to length
- Perfect for cutting a recess in furniture components
- One HCS 32 x 40mm plunge-cutting saw blade for wood
- One HCS 85mm segmented saw blade for wood
- One BIM 20 x 20mm plunge-cutting saw blade for wood and metal
A convenient selection of three different blades within one package suitable for many cutting applications. The three piece universal set includes two blades which are suited to cutting wood and one for cutting wood and metal.
The blades are ideal for plunge cutting into solid wood, softwood and plasterboard. Use for flush cutting wood, copper pipes and plastic pipes (PVC) to length or for cutting a recess in furniture components.
The blades will fit Bosch, Makita and Fein (10mm) multi-tools and others using the Oscillating Interface System (OIS™) and Starlock fitting which ensures a secure fit with maximum power transfer. For reference, Starlock fits all New Bosch Starlock Multi-Cutters, Old Bosch Multi-Cutters (OIS Interface), New Fein Starlock Multi-Cutters, Old Fein Multi-Cutters (OIS Interface) and Makita OIS Multi-Cutters.
