Bosch AIZ 32 EPC C-Tec HCS Plunge Cut Blades (Starlock)
- High carbon 32mm steel blades
- For cutting wood and plastic and other similar materials
- Cut up to an edge or in the centre
- Clean cutting
- Allow for a deep plunge cutting
- Starlock fitting for maximum power transfer
Bosch BiM C-Tec Precision Plunge Cut Blade (Starlock) - 32mmFrom £13.38 £11.15
Bosch BiM C-Tec Japanese Style Plunge Cut Blade (Starlock) 65mmFrom £16.78 £13.98
These high carbon 32mm steel blades will cut wood and plastic and other similar materials, they cut right up to an edge or in the centre of material giving a clean cut as well as allowing for a deep plunge cut if required. Curved-Tec used on the end of the blade features a rounded cutting edge for smoother and more precise plunge cuts as well as reduced tooth breakout on the sides.
Suitable for Bosch, Makita and Fein (10mm) Multi-Tools and others using the Oscillating Interface System (OISâ„¢) or Starlock fitting for a secure fit with maximum power transfer.
