Bow XT Feed Supports
- Designed exclusively for XT Xtender Fence system
- Enhance workpiece support
- Improve safety and cut quality
Unparalleled control, precision, and versatility
The revolutionary BOW XT Xtender Fence range will become your number one companion when it comes to sawing. Here are the key components that make it so impressive:
The fences
Strong, rigid and durable, the fences are engineered in heavy duty aluminium extrusion and are available in 24”, 36” and 46”. They will extend your existing saw fence by these lengths respectively, drastically improving your support on any site saw, compact table saw or bandsaw.
The clamps
Coming as a pair, these classic T-Track clamps are designed perfectly for the XT Xtender range. They slot securely into the milled T-tracks of the fences.
The feed supports
Able to be positioned in front of the blade or behind, these supports do just that…significantly improve support for your work. Plus, you can slot a standard 2x4 into the cavity underneath to give even stronger support.
The system
- Each fence has multiple milled T-slots
- Effortlessly attach the XT Xtender fence to existing fence
- Position it best for you: forward/infeed, centre, or back/outfeed
- Easily set up, remove or change the fence position in seconds
The benefits
- Remarkably versatile
- Quick and convenient
- Use anywhere – onsite or in a busy workshop
- Easy storage with hanging hole on the fence
Most importantly: better support, better safety, better cut quality, better feed control.
The BOW XT Feed Supports are an essential accessory, designed exclusively for the XT Xtender Fence system.
Sold as a pair, the XT Feed Supports attach easily to the BOW XT Xtender Fence and can be positioned in front of or behind the blade, significantly extending a saw's table surface and improving support of the workpiece. They are ideal for use with compact saws, portable saws, or bandsaws. The XT Feed Supports feature a cavity underneath, designed to accommodate a standard 2x4 for added support when cutting long or heavy boards.
The benefits to using the XT Feed Supports within the XT Xtender Fence: significantly enhance workpiece support, safety, and cut quality.
