UJK Bandsaw Buddy
101807
From £19.98 £16.65
  5. Half Star
252 Reviews
In Stock - Ready to dispatch
Unused returns, open-box items, or cosmetically imperfect products, fully inspected and offered at a discount: UJK Bandsaw Buddy (Cosmetic) *Refurbished*
From £16.98 £14.15
  • Designed and made in Axminster
  • Unique bandsaw blade aligning tool
  • Checks the alignment of blade to the face of the fence
  • Rare earth magnets hold it firmly on the blade
  • 250mm long makes it easy to spot any discrepancy
  • Scale on the tip helps set fence for cutting veneers or thin boards
  • Holes for drawing circles in 25mm steps from 75 to 400mm
  • Accurately machined from anodised aluminium
Four great uses, one small price!
Designed and manufactured here at Axminster HQ, the Bandsaw Buddy is the must-have accessory for every bandsaw owner out there. Do you need an easy, quick and accurate way of aligning your blade, fence or table? Perhaps you’re looking for a quick way of marking bowl blanks, or maybe you want precise, wafer thin veneers for that furniture project. Always keep your buddy on hand, the integrated magnets allow simple storage on your bandsaw, keeping it close to hand and ready for action.
Blade Alignment Tool
Rare earth magnets securely hold the rule to the blade. This enables you to align your rip fence and table perfectly parallel with the blade. Always use it on a new blade. Why? An old blade may have been twisted or kinked during use, knocking out the accuracy.
Thickness Gauge
A convenient and accurate metric thickness gauge, great for veneering.
Circle Marking Gauge
Draw circles for bowl blanks from 75mm to 400mm radius in increments of 25mm.
Straight Edge
Accurately machined from anodised aluminium, it's handy for accurate marking.
Advice from our experts
Explore Woodworking Wisdom...
"...it ensures fence and blade alignment"
Read our Product Guide
How to Set Up a New Bandsaw
See our step-by-step guide
The UJK Bandsaw Buddy is a unique bandsaw blade aligning tool. Bandsaw Buddy allows you to check the alignment of the bandsaw blade to the face of the fence. Most other checks only require the use of a combination or engineer’s square. Truing the fence to the blade is tricky. Bandsaw Buddy has two rare earth magnets which hold it firmly on the blade. At 250mm long it is easy to spot any discrepancy and then make necessary adjustments. The magnets will keep it safely stored on the bandsaw’s frame when not in use. A scale on the tip helps set the bandsaw fence for cutting veneers or thin boards. Holes along the Buddy’s length at 12.5mm intervals allow you to draw arcs or circles in 25mm steps from 75mm to 400mm, a useful feature for marking curves or when cutting bowl blanks. Accurately machined from anodised aluminium, it also makes a handy straight edge. The UJK Bandsaw buddy can be used for bandsaw blades between 3/8 - 1".
British Made British Made
4.30 252
