Button Fix Router Multi Jig for Type 1
106321
From £73.98 £61.65
2 Reviews
Low Stock - Ready to dispatch
  • For cutting the rebate for Type 1 Button Fix, Type 1 Bonded, Type 1 Metal and Type 1 Flush
  • Includes fixing pilot holes for rebated and surface mounting
  • Requires a router with a 12mm cutter and 16mm guide bush
  • Countersunk holes for screwing directly onto the panel
  • Pilot holes require a 3mm drill bit
This router jig helps to cut the rebate for all Type 1 Button-fix, and to position the fixing pilot holes for both rebated and surface-mounted installations. The jig requires a router fitted with a 12mm cutter and 16mm guide bush. The jig features countersunk holes for screwing directly onto the panel to position the Button Fix wherever it is required. The pilot holes require a 3mm drill bit. Size 250 x 180 x 8mm.
British Made British Made
4.00 2
