Button Fix Button Marker Tool Type 1 & Type 3
106317
106317
- Accurate marking for button when using Fix Type 1 & 3
- Leaves indents showing exact positioning
- Reusable for next panel, pack contains 4 button markers
These markers make a handy accessory helping you to mark out where to install Button Fix Type 1 and Button Fix Type 3. They simply snap into Fix; you can then place and position the panel where you want it to go. A firm tap on the panel will leave indents on the rear of the panel, indicating the exact position to place the real Buttons. Remove the markers, which can be reused when marking out the next panel. Always remember to allow at least 15mm clearance above the removable panel. Each pack contains 4 button markers.
