Button Fix Type 1 & Button For Countersink Wood Screw
- Award winning, secret fixing for panels, signs, notice boards
- Easy to install; excellent solution and great time saver
- Simple system engages with a downward push
- Quick and easy fitting, parts click together
Button Fix Type 1 Flush Fit & Button for Countersink Wood Screw - Pkt 12From £13.48 £11.23
The Button Fix Type 1 are easy to fit and very effective for attaching panels, signs, fascias, bulletin boards etc without any obvious or external fixing. The Button Fix Type 1 attaches to the wall and the button to the rear of the panel. Both parts are ultra tough glass filled nylon. This simple system engages with a straight downwards push for a secure and secret panel fixing.
The Button Fix Type 1 clip is 55mm wide, 45mm tall and 8mm thick, fixed using 2 x 4.5mm pan head screws. The button is 18mm diameter by 8mm thick and requires a single 5mm countersunk screw. Using the router jig to cut a recess for the Button Fix Type 1 cuts the spacing off the wall to a mere 3mm. Available in packs of 12 or 100.
