Button Fix Pad For Type 1 Bonded Fix (Pkt 12)
106319
From £6.48 £5.40
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Double sided, self-adhesive pads for Type 1 Bonded Button Fix
  • Pre-cut to match the outline of the Fix
  • Easy peel backing, ideal when speed of assembly is important
  • Supplied in a pack of 12
A pack of 12 double sided, self-adhesive pads for use with the Type 1 Bonded Button Fix. Each one is pre-cut to match the outline of the Fix. With an easy peel backing, these pads offer great convenience. They are ideal for light duty applications where speed of assembly is important. For the best results, use the Fixes in the rebated configuration to avoid possible creep under loading. If using Fix-pads in the surface mounted configuration, the loading should be limited to a maximum of 2kg per Fix.
British Made British Made
