Japanese Carver's File - Round 8mm Fine 200mm
104305
From £24.98 £20.82
4 Reviews
In Stock - Ready to dispatch
  • For carvers, cabinetmakers, musical instrument makers and sculptors
  • Leaves a surface that requires very little further finishing
  • Teeth are milled and chemically etched for maximum bite
  • Built-in chip-breakers minimise clogging
  • Suitable for wood, plastics and other similar materials
These Japanese round files perform superbly when working on internal curves or opening up holes or expanding slots.
The blade is 8mm in diameter and fitted with a contoured wooden handle. The cutting length is 185mm with fine teeth for a smooth finish. The total length is 315mm. These files are ideal for carvers, cabinetmakers, musical instrument makers and sculptors. They are capable of the accurate removal of timber on difficult or awkward grained wood. Rasps produce sawdust, files make filings (dust); an Iwasaki carver’s file produces miniature shavings. Like a rasp, an Iwasaki file removes material very quickly but the resulting surface is much smoother, requiring only a little sanding to finish.
Made in Japan.
4.00 4
