Chroma Craft Rustina Metallic Paint - 236ml
- Second stage in creating the look of ancient corroded metal
- Suitable for wood, metal, ceramic, glass and plastics
- Paint contains real metal particles
Chroma Craft Rustina™ Primer - Black 236mlSpecial Price £9.06 £7.55 was £15.58 £12.98 Save £6.52 £5.43
Chroma Craft Rustina™ Primer - Road Rash 236mlSpecial Price £9.17 £7.64 was £18.38 £15.32 Save £9.21 £7.67
Chroma Craft Rustina™ Primer - Gun Metal Grey 236mlSpecial Price £7.64 £6.37 was £15.58 £12.98 Save £7.94 £6.62
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Ageing gracefully with Rustina™
This unique paint ageing system for the Nick Agar Signature Series from Chroma Craft will definitely give your workpieces the wow factor. The water-based paint system is easy to use and creates the look of ancient corroded metal on almost any material.
Turn any project into a rusted artefact with this simple four step paint system.
Step 1. Choose a primer - choose either a Gun Metal Grey or Black Primer or the textured primer Road Rash. Road Rash is a grit like undercoat that gives your workpiece a gnarly, corroded iron effect and can instantly transform one material into an aged piece of metal.
Step 2. Next apply your chosen metallic paint - choose either copper, bronze or iron for the specific metal result you are looking to achieve. The metallic paints contain real metal particles, which when activated, using the Chroma Craft Rustina™ Aging Solution, will create a rusted, aged effect.
Step 3. Apply the Rustina™ Aging Solution - spray, brush, sponge or dab on the ageing solution onto the wet metallic paint and wait. Depending on the ambient temperature and humidity the change can take 20 minutes to a couple of hours. The finish produces actual patina or rust, in various shades, to provide a realistic aged effect. There are two colours available, either a blue-green colour for a verdigris effect, or use brown-rust for a more traditional rusted effect.
Step 4. Finish with a top coat of Chroma Craft Sealer WRU-20, for a long lasting protective finish. It offers a tough, chemical-resistant finish that is easy to apply and offers outstanding durability and adhesion.
Chroma Craft Rustina™ is a unique water-based system, which you can use to produce the look of ancient corroded metal on a variety of surfaces including wood, metal, ceramic, glass and plastics. Developed with Woodturner Nick Agar, this system imparts a realistic aged blue/green verdigris or a red/brown rust effect on turned objects and other items. It is a simple four stage process that only involves wielding a paintbrush.
These metallic paints are applied over the primer colour. The paint contains real metal particles. These particles react with the ageing solution when it is applied to the still wet paint, to give the appearance of aged metal. The iron paint turns a reddish brown giving a genuine looking rust effect. The bronze and copper the greenish look of old verdigris.
