Bushing Set for Tooling Stylus Pen Kit
104367
104367
- Bushings mount onto a pen mandrel
- Enables you turn to exact diameter required
- No need to measure progress
- Precision made using CNC production
- Helps to speed up production
- Used to turn Tooling Stylus Pen Kit (104356)
The use of a pen mandrel with the correct bushing set makes pen making and turning project kits an easy process. Simply use the bushings on the mandrel as a reference to turn your blanks down to the correct diameter.
