Seasonal Tree Decoration Kits
- Make some great decorations using timber or acrylics
- Quick and easy to make your own creations
- An inexpensive way of using up your offcuts
Micro-Mesh Soft Touch Abrasive Pads 50 x 50mm - Mixed (Pkt 9)From £15.58 £12.98
A simple kit comprising a brass tube with a decorative finial at one end and a means of attachment for hanging at the other. They are a great way of using up your offcuts to produce some unusual designs for seasonal tree decorations at Easter or Christmas. We are sure the more imaginative among our customers would find many creative ways of using this kit. The brass tube for instance, could be swapped for one of our 7mm pen kit tubes which are 10mm longer and available in packs of twenty. For Easter decorations, turned egg shapes using this kit for hanging them would look great. Our project kit blanks would make a great choice of material for producing some colourful designs and you could just use the top hanging section and drilling a blind hole for the brass tube.
Bushing Set Order No. | 8.5mm O/D (as supplied with mandrel) (100793) |
Difficulty | Beginner |
Drill Bit Required | 7 mm |
Minimum Blank Size | 50 mm long |
