From £129.98 £108.32
In Stock
  • Premium quality tool with replaceable carbide tip
  • Ultra long lasting cutting edges
  • Simply turn to fresh edge when dull
Customers Also Bought
Ingenious woodturning tools
Tough, durable and razor sharp, the Crown Carbide Turning Tool range is a cut above the rest. Start turning straight out the box with Crown’s carbide tipped woodturning tools. The Crown Carbide range features solid tungsten carbide cutters, which are long lasting, tough and razor sharp.
The ultimate edge
The toughed cutting tips make the Crown Carbide Pro turning range highly efficient when turning wood, acrylic, polyester and resin. And with no need to sharpen, you can turn straight out of the box! When the carbide tips start to lose their edge, a simple sharpen will bring them back to life, or replace the tips when needed.
Controlled cutting
Each tool features a 20mm x 13mm shaft, made from super tough chrome vanadium steel, which helps smooth out vibration. The weight keeps the tool on the tool's rest and, combined with a 355mm long handle, ensures effortless control. The tools work best when flat and level, cutting at centre height or, with the handle slightly raised, cutting just below centre. The sides of the bar have a gentle radius allowing controlled shear cuts.
Fine Detail
Carbide Hollowing Tip
The Hollowing Tip Turning Tool has a 15mm diameter circular cutting tip, and is perfect for cutting coves in spindle work.
Carbide Roughing Tip
The Roughing Tip tool features a 15mm square cutting tip, and is great for removing material quickly. It is also capable of delicate refining cuts, flat or at a shear angle.
Carbide Detail Tip
The Detail Tip Turning Tool has a diamond shaped cutter, with 15mm long edges. The acute angle point is perfect for fine detailing, deep vee cuts, and the side edges are good for refining convex curves.
Crown Carbide Pro turning tools are the result of a long time spent in design, research and testing. These premium quality tools fulfil the expectations of the professional woodturner.
At the business end is a solid tungsten carbide cutter, sourced from a well-respected manufacturer in the USA. The tips are made from the finest nano-particle carbide that is hardened to an unbelievable 93 HRC; this makes them ultra long lasting and, when the edge eventually dulls, all you need do is turn the cutter to a fresh sharp cutting edge. The Roughing Tip tool features a 15mm square cutting tip, each side having a very slight radius. It can remove quite a lot of material quickly. On the other hand it is more than capable of delicate refining cuts, flat or at a shear angle.
Crown Carbide Pro turning tools are highly efficient when turning wood and are very effective when turning acrylic, polyester and resin. The tools have good heft and mass; the 20mm x 13mm shafts are super tough, made from chrome vanadium steel, which helps smother vibration. The weight keeps the tool on the tool's rest and, combined with a 355mm long handle, ensures effortless control. In use, the tools work best when flat and level, cutting at centre height or, with the handle slightly raised, cutting just below centre. The sides of the bar have a gentle radius allowing controlled shear cuts.
Each tool comes with a hex key and spare machine screws.
  • 15mm square tip has slightly radiused edge
  • Removes material quickly
  • Capable of delicate refining cuts
  • Suitable for turning wood, acrylic, polyester and resin
  • 20mm x 13mm solid steel shaft smothers vibration
  • 355mm long handle for effortless control
Made in Britain Made in Britain
    4.60 17
