DeWALT DT20701 Multi-Tool Blade Wood & Nails
508646
508646
- Online exclusive
- Suitable for use on timber embedded with unexpected nails
- Bi-metal construction, for maximum longevity
- Blade length: 43mm; blade width: 30mm
- Suitable for use on most oscillating multi-tools
- Ideal for cutting wood with or without nails, plasterboard, PVC
The DeWalt Multi-Tool wood and nails blade is suitable for use on nail embedded timber and resists damage to the teeth when encountering unexpected nails. The blade has a bi-metal construction, ensuring that it maintains a sharper edge for longer. The cutting depth maximises the areas that the tool and accessory can be used in. The blade is quick and easy to change, and can be used on most oscillating multi-tools. It is ideal for cutting wood with or without nails, plasterboard, PVC.
Blade length: 43mm
Blade width: 30mm
