Easy Wood Tools Ci3 Carbide Cutter - Round
109312
From £15.18 £12.65
3 Reviews
  • Fits: Easy Start Easy, Mini Easy and, Mid-Size Easy Finishers
  • Fits: Full-Size Easy Rougher and Pro Easy Rougher
  • Fits: Full-Size Easy Hollower #3 and all Pro Easy Hollowers
  • 11.5mm diameter, solid carbide
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci3 solid carbide cutter is 11.5mm diameter. It fits the Easy Start Easy Finisher, Mini Easy Finisher, Mid-Size Easy Finisher, Full-Size Easy Hollower #3, Pro Easy Hollower #1, Pro Easy Hollower #2, and Pro Easy Hollower #3. Full-Size Easy Rougher and Pro Easy Rougher.
​The standard carbide cutters provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
5.00 3
