Easy Wood Tools Ci6-SQ Carbide Cutter Square
109211
From £15.78 £13.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Fits the Micro Easy Rougher
  • 9.3mm square, solid carbide
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible.
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci6 solid carbide tip is 9.3mm square. It fits the Micro Easy Rougher
​The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
